rear disc break conversion on 95 civic dx
Old Dec 15, 2004 | 10:50 AM
vinnyzcrx's Avatar
vinnyzcrx
Default rear disc break conversion on 95 civic dx
does any one know anything about having to change the master cylinder in doing a rear disc break conversion? i already have the perportion valve and the rear disc breaks but i heard that the master cylinder had to be changed also? does anyone know?
Old Dec 15, 2004 | 11:04 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
http://www.honda-tech.com/zerothread?id=818263
I have it here too...but dont know where it is
Old Dec 15, 2004 | 11:06 AM
randomtask77's Avatar
randomtask77
Wanderer
http://www.hybridgarage.com/tech/brake2.html
bambbrose's Avatar
bambbrose
it's not needed.. but it will improve braking power. You can get a master cylinder from a non abs RS integra and that bolts up, or some like 91 civics, I forgot which models.
Old Dec 15, 2004 | 11:17 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
91 civic EX SEDAN ...it will be a 15/16 MC that will bolt up to the non abs booster.
Old Dec 16, 2004 | 06:34 AM
93civicsedan's Avatar
93civicsedan
I have a 15/16" master cylinder from an integra RS. you will need an integra non-abs booster and it will bolt right in to your car. pm me if you are interested.
Old Dec 16, 2004 | 07:28 AM
Outxider's Avatar
Outxider
X-Motoring
im runnin the same setup with my gsr brakes all around. works great for me.
Old Dec 16, 2004 | 10:09 AM
wilsel's Avatar
wilsel
Same here, haven't driven a swapped one without the MC upgraded. But people that have driven their cars both ways usually say it make a big difference with the larger MC.
Old Dec 16, 2004 | 10:12 AM
Nelson's Avatar
Nelson
Administrator
That's what I used.
That works too
I've driven it a few ways, I'll just go on and say that driving without upgrading the MC felt really silly, because the pedal needs to be depressed alot more than you should have to.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Dec 16, 2004 | 12:14 PM
huviduc's Avatar
huviduc
i have a95 dx civic with rear disc conversion. i called up the honda dealer and talked to them. they told me it is not needed at all to do a MC change. It uses the same one, he told me the only thing needed was the rear brake set up and thats it. anything else id be wasting my money. i put them in they work great. he said it depended on alot of different things, if you just call them up and give them all the model specs and such. they will tell you what needed.
