basic question
Old Nov 13, 2004 | 09:23 AM
civicburner's Avatar
civicburner
Default basic question
How come you can push start a car with a manual transmission and not an auto transmission?
Old Nov 13, 2004 | 09:26 AM
ikarus's Avatar
ikarus
because u cant start a auto car in neutral only in park
Old Nov 13, 2004 | 10:41 AM
Kestrel's Avatar
Kestrel
Push to shock!
I think the neutral/park starting business is just an interlock to prevent preople from starting their car in drive.
So when you push start a car, the transmission is spinning the engine the way the starter would, just using the car's momentum instead. In a manual this is possible because the clutch makes a direct connection between the engine and tranny. In an automatic, the torque converter makes this connection, but the torque converter is a viscous coupling device and not a direct coupling, so there's not enough of a connection between the tranny and engine to rotate the crank.
Old Nov 13, 2004 | 10:47 AM
civicburner
now that is a good answer. Thanks.
Old Nov 13, 2004 | 01:07 PM
BrianDB1's Avatar
BrianDB1
40 Below Summer's Child
you can start an Auto in Nuetral, but not Drive or Reverse.
Old Nov 13, 2004 | 01:56 PM
civicburner
wow I never know that, cool
Old Nov 13, 2004 | 04:21 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
wrong
Old Nov 13, 2004 | 04:35 PM
Hondaman's Avatar
Hondaman
Black Pearl
You can push start an automatic. You just have to be going fast enough to do it. I think if you get up to about 15-20MPH and put it in D1 it will work. At least that's what I've been told. :dunno:
Old Nov 13, 2004 | 04:37 PM
19.3secS2K's Avatar
19.3secS2K
I've heard turning the key works alot better :chuckles:
Old Nov 14, 2004 | 11:34 AM
Kai's Avatar
Kai
Rotorphile.
In any case, push starting is a bad idea. Only do it in emergency situations.
