new stance
my bum is on the swedish!
hfawk:
not the best pic in the world (dirty car :a: ), but there it is.... the drop is about 2.25"
too bad my camber is shot to hell
h: the rears are like -2.1 and -2.6
will the washer trick do any good for the rear camber? Or should I just get front and rear camber kits? Also, what are some suggestions? The shop I get alignments and stuff done at can get the ingalls kits, but they quoted me about $1300 for front and rear control arms, and front ball joints, plus install and the alignment. I don't like that price
comments?
the rear washer trick will work fine. It does the same thing, and I corrected mine that way. Got it to -.7 and -.8 which is were I wanted it to be. as for the fronts, I would suggest some omnipower UCA's, and 1320 to install and align is outragous. I'd do it for 250 if you lived around here
but yeah, most of that $1300 was the front and rear control arms and the ball joints ($700, ingalls). $400 for install, and $100 for mis shop crap, plus the alignment ($80)
you can purchase the omni power, skunk2, ingalls, for less than 2 hundred for the front. And intall on them is very easy (at least the control arm one is). I even think omni has specials for front and rear for a pretty cheap price like $250 or so, I remember seeing it awhile back not sure if they still do. But you can probably get away with washers in the back since those tires don't turn, they won;t wear out that fast.
I think I used 2 washers on one side, and 3 on the other, which really means 4 bolts and 10 washers total. I'm was using ground controls with stock rates, dropped probably 2" but I'm not sure, might be a tiny bit more.
Originally Posted by NeverBX
actually you dont even need longer bolts, just the washers 3 per bolt so you will need 12 total. but i just went ahead and got longer bolts anyway. i think the bolt you need is a m10 make sure the tread is 1.25 and not 1.5 or it wont go in right. and make sure you put the washers between the body and the arm not the arm and the bolt head.
I've heard 1/32 washers is the correct size?
I still haven't even looked at front kits yet....
Originally Posted by randomtask77
The stance looks great! :goodjob:
It almost detracts from the fact that you have to paint the rest of your car.
hfawk:
hfawk:
:reechy:EDIT: this car also has black trim :db:
