OBD1&2 issues
Old Nov 4, 2004 | 08:47 PM
CRAZYEG9's Avatar
CRAZYEG9
THE TRUE O.G.
Default OBD1&2 issues
When I'm ready to put my 96-01 OBD2 B20 in, what engine accesories must be swapped for OBD1, I know the distributer, but I'm not sure about the alternator, fuel injectors, or starter. It's for a 92 Civic. Please help me on this.
Old Nov 5, 2004 | 08:25 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
it depends on which engine harness you are planning on using.
if you're using the '92 harness, then you either need to change the plugs on the alt, distributor and injectors or swap them for OBD1 units.
I used the OBD2 engine harness that came with my swap, switched around a few wires and pluged it into my '92 chassis harness at the shock towers and everything works perfectly.
