Stalling after valve adjustment
Old Nov 1, 2004 | 05:01 PM
anthony46k's Avatar
anthony46k
Default Stalling after valve adjustment
My engine was noisy in the morning so I thought i might need a valve adjustment. So i went to my mechanic and had it done. The next morning after about 3-4 minutes, my rpms dropped and the engine cut out. I restarted it but it
did the same thing. After about 10 mins though, this stops happening, but rpms still seem low at times. I went back to have it checked out, says they readjusted some but i still have the same problem. What could be causing this? Everything else seemed fine before I brought it in the first time.
Have 97 civic ex 134,000miles automatic
Old Nov 1, 2004 | 05:41 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
define noisy.... where under the hood was the noise coming from?
what does the mechanic normally work on? just honda/acura? all vehicals? is he reputable?
perhaps your ecu needs to be reset?
Old Nov 1, 2004 | 06:34 PM
anthony46k's Avatar
anthony46k
ill try to define - somewhere in the range a noisy lawnmover makes, or a noisy old vw bug. Basically it sounded rough - particularly the more gas and rpms the louder it sounded - when the engine was cold.
the mechanic is reputable. He works on everything.
how would i go about resetting the ecu? i tried pulling the back-up/ radio 7.5 fuse for ten seconds - the chilton said this resets the pcm (powertrain module) - it that the same thing?
Old Nov 1, 2004 | 06:42 PM
19.3secS2K's Avatar
19.3secS2K
hmmm, from what I can tell, you did the right thing....
if thats the case, maybe have him look at it more? its kinda hard to diagnos car problems online h:
thats correct. You can pull the power wire off the battery, too.... then let the car idle for a few minutes
Old Nov 1, 2004 | 08:23 PM
Outxider's Avatar
Outxider
X-Motoring
sounds like he adjusted it out of range.
Old Nov 1, 2004 | 09:02 PM
Hondaman's Avatar
Hondaman
Black Pearl
If the noise is gone, then I would bet he set them too tight. You may want to run a compression test on it to varify.
Old Nov 2, 2004 | 09:09 AM
anthony46k's Avatar
anthony46k
It seems like after the adjustment, that the rpms are very low (100-200rpm)at cold to less cold (0-15 mins of driving) but go to about 500 at fully warm. Does this sound like a symptom of adjusting the valves whenthe engine is too hot?
Old Nov 2, 2004 | 09:19 AM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
To reset your ECU you disconnect the battery for 10 min, and then reconect the battery and start your car (donot give it any gas) dont touch the throttle, and let it idle untill it gets warm. That should do it.. If not, take it back, he obviously did somthing wrong...
Old Nov 2, 2004 | 09:46 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
check your oil? no oil makes for loud valvetrain.
Old Nov 2, 2004 | 10:33 AM
anthony46k's Avatar
anthony46k
oil level is good
