another check engine light question . .sorry
Old Aug 16, 2002 | 07:32 PM
Max Power's Avatar
Max Power
Buff Member
Default another check engine light question . .sorry
ok i found the connector that you're s'pose to stick the paperclip in, but there are already two wires coming out of it. . . . do i just pull these wires out and stick the paperclip in?
Old Aug 16, 2002 | 07:33 PM
crucial Si's Avatar
crucial Si
Banned
Default Re: another check engine light question . .sorry
as in what..can you get a pic?!?
but anyhow...if it make a connection go ahead and do it..
Old Aug 16, 2002 | 08:15 PM
sinthetiq's Avatar
sinthetiq
are the two wires connected, if not, try touching them together and running the diagnostic tests
Old Aug 16, 2002 | 08:23 PM
crucial Si's Avatar
crucial Si
Banned
turn your key to the II mark but not igniting the ignition.
Old Aug 16, 2002 | 08:38 PM
Max Power's Avatar
Max Power
Buff Member
that blue connector is connected to a green thing in my car, i think i have to take it out and thats the side i put the paperclip in. but its hard under the tight spaces under the car. im gonna try again tomm.
Old Aug 16, 2002 | 10:18 PM
OneToughCivic's Avatar
OneToughCivic
what year is your car? on my 5th gen, there is nothing plugged into the blue 2 pin plug. it just sits there behind the kick panel.
Old Aug 17, 2002 | 12:46 AM
pimpdaddypat's Avatar
pimpdaddypat
i have a 96 civic ex and mine is a brown connector and it rest in a green housing plastic case...
so maybe thats what your talking about is the case that it is stored in and there is like a another connector in the case also..
if so then its the two wire one and it should pull right out
i also have a 92 civic vx hatch and its the same way
Old Aug 17, 2002 | 12:47 AM
pimpdaddypat
i just re read one of your posting and saw you said it was in that green thing...
yea just pull it out of there.... it might be hard to get it out but it will come out
Old Aug 17, 2002 | 08:57 AM
Max Power's Avatar
Max Power
Buff Member
yea i think im spose to pull it out but its hard to get a hold of, and i dont wanna pull it by the wires cuz it might pull our or sumthin bad, i'm trying it right now
Old Aug 17, 2002 | 08:59 AM
Max Power's Avatar
Max Power
Buff Member
yea i have a 98 and its in a green rubber holder of some sort
