Rust!
Old Oct 24, 2004 | 07:06 PM
ShuengChang's Avatar
ShuengChang
1992 Honda Civic
Default Rust!
I have a rather large spot of rust on my rear quarter panel on both sides. It is also on the bumper some what, which makes it not hold together completely and basically looks nasty as hell. What parts would I need to get to replace them, and where? Is it an expensive fix?
Old Oct 24, 2004 | 07:13 PM
Nelson's Avatar
Nelson
Administrator
I doubt there is rust on your bumper, it's made of plastic
You can't really replace your RGP's, so you'd have to either have a shop sand and get rid of the rust / repaint or have it electrically removed. I don't know how the latter works.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Oct 24, 2004 | 07:16 PM
ShuengChang
1992 Honda Civic
How much do you think that would cost?
Old Oct 24, 2004 | 08:19 PM
bambbrose's Avatar
bambbrose
its not cheap thats for sure. if the rust is bad and all the way through, they have to cut out the metal, and weld in a new peice of the panel, and then sand smooth, repaint, etc.. Not cheap for sure. Labor intensive
Old Oct 24, 2004 | 08:26 PM
Civic2Scooby's Avatar
Civic2Scooby
:werd: I just noticed my rear qurater panel rust has turned into a hole.....spring welding/body work..here I come.
Old Oct 24, 2004 | 10:02 PM
Hondaman's Avatar
Hondaman
Black Pearl
It's funny you ask. I just got three estimates done to fix a small bubble on the rear fender-well of my 96 civic. Here's what the guys told me.
The first step that needs to be done is to prep the area in question. They do this usually with sand blasting. If the metal is strong enough so that the sand does not blow holes through or if the rust has not gone through the metal, it can be Bondo'd, painted and sent on its way. Total cost was about $150
If there are small holes or a large hole, the area will need to be cut out with a new section put in its place. This requires cutting, welding, grinding, etc. This raises the price to about $500.
Most places will not guarantee the rust repair either. If it should happen to rust again two years down the road because of galvanic corrosion (two dissimilar metals welded together) you are again out another $500. In talking to the guys, all agreed that if I did it now, or if I waited three years, it would still cost the same.
Keep in mind, the spot on my car is about the size of two dimes placed next to each other.
