Del Sol/D16Z6 Question
Old Oct 18, 2004 | 01:26 PM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
Default Del Sol/D16Z6 Question
Would it be safe to run the stock headers without the heatshield? Im needing to replace some bolts, but until then the heatshield rattles, so im curious if i can just run without it?
Let me know.
Old Oct 18, 2004 | 01:52 PM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
*bump*
Old Oct 18, 2004 | 01:58 PM
Snoopy's Avatar
Snoopy
been there done that
it'll be hotter in the engine bay, but it'll be fine
Old Oct 18, 2004 | 02:04 PM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
Well im gonna be dropping on new headers and working on a cold air intake.
So i should be safe then.
Old Oct 18, 2004 | 02:23 PM
Snoopy's Avatar
Snoopy
you have one header
Old Oct 18, 2004 | 02:26 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
you have one header
thank you! :uhhok:
Most aftermarket headers don't have a heat shield.
Old Oct 18, 2004 | 02:27 PM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
you have one header
You know what i mean. h:
Snoopy's Avatar
Snoopy
Originally Posted by westcoaststyle
thank you! :uhhok:
no aftermarket header has a heat shield....that i've seen at least.
Old Oct 18, 2004 | 02:50 PM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
Do aftermarket run the same temp or cooler then oem?
Old Oct 18, 2004 | 02:53 PM
Snoopy's Avatar
Snoopy
the stock manifold is a heavy cast iron piece and gets really hot hence the need for heatshields in the first place. aftermarket headers are made of tubular steel. some are ceramic coated or have some other form of heat coating. so i'd venture to say they will run cooler than stock, but its not like i've checked how hot they get. just an assumption. :dunno:
