Its not strong enough
i want to know how i can make my a/c blow harder than it does. Also how can i make it ice cold?? It doesnt blow out as cold as it should. i have a 5th gen 4 door with a d15 pos.
turn fan to the 3rd setting.
unless you are out of freon...
what exactly are you expecting? your civic isnt a windtunnel.
if your freon is low...recharge it. if you want the most wind force out of your vents, point them in your face, turn up to the 3rd setting on the fan, close the middle top vent..and turn on the recirculate function.
I would check to make sure your A/C condensor is clean and all the parts of the A/C are clean/snag free. Then recharge and you're set.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Originally Posted by Zzhatch
it is obviously not a wind tunnel, the freon has been recharged and all my settings are like that already. you dont know how to make it blow harder, so your input is worthless to me you said it to be rude, it really isnt helpful. My firend has the same car that i do and his A/C blows a lot harder than mine, i was wondering what i can do to make it blow as hard, it does not feel like it is blowing as high as it should.
Rude huh? Im trying to give some help and probably gave you the most input in this thread. If this reply is worthless and unhelpful, then just ignore it.
You are either out of Freon or have a leak or snag in your vents. Thus causing it to not be as "cold" or blow as "hard" as your friend's setup.
There's my final rude and worthless 2 cents.
