Camber kit
Originally Posted by 18secFerio
actually, the guy who does Omni used to work for skunk2, or thats what I've heard
I never mentioned the Skunk camber kits were the same as Omni's.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Originally Posted by pomansouth
this just may imply that they are the same.
h:Anyways.
Back on topic.
I've heard good things about the Skunk (and the designs similar to it) the only complaint I've heard was some of them slide (the adjustment) but I believe newer designs fixed this.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
soooo what you are saying is that skunk2 and omni are the same thing, just that one is cheaper then the other. you have got to be kidding me.
you do know that the founder of Omni Power designed the original Skunk2 design right? so yes...they are the same. both designed by the same guy...and both made in TAIWAN. Skunk2 has been around longer and established themselves. but they ARE the SAME design...and yes..one sells for more money than the other.
if you're not going to need camber adjustments very often, I'd go with ingalls.
if you want an adjustable a-arm style, I'd go with SPC over skunk2. Many folks have found the hardware on the s2 kits just doesn't hold up and slips or breaks over time. People who are hard on them often have to modify the s2 hardware with better stuff to make it work. People have also had problems with the inside edge rubbing on the inner fender/strut mount area. I've never heard of any problems with SPC.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
so here's a question...
Omni sells their kit for $160 at Modacar, and it mentions something about rear shims....
found here: http://www.modacar.com/products/Honda/Civic/OPFUCA
so do I need a rear kit then? Or are the rear shims something else?
or should I get the ingalls kit instead?
not a track car, but I'm a daily driver that see's lots of highway
Originally Posted by modacar
Omni-Power adjustable front camber kits are designed to replace the whole factory A Arm allowing up to +- 4 degrees of camber adjustment.
Camber Kits come equipped with high quality ball joints and nuts able to withstand track abuse as well as the rigors of everyday street driving.
These are the same kits supplied to Race Winning World Challenge Driver Roger Foo! Rear Shim Kit Included, Installation Instructions. Sold in sets of 2.
the shims should do you as long as you're not looking for a really precise allignment.
For a daily driver (one that wont be getting allignments often or wont have the ride hight changed often) whatevers cheapest will do fine.
