ITR Rear Sway, quick question
Hey everyone, just picked up a 92 Civic Hatch CX and I was looking in to the ITR 22mm Rear sway bar. I have a 14mm GSR rear sway in my garage and i have the D bracket and the endlinks still on it, probably needs new bushings.... but anyways can i just order the 22mm rear sway and use the GSR sway bar mounts? and is it a "MUST" to have the BSQ or Beaks mounting kit?
btw, before u start flamin me on ripping my subframe, the hatch is stripped and will be running 400-450lb/in springs in the rear.
THANKS!!!
THANKS!!!
it is not a must for the kit...but highly recommended. most likely..you will tear the subframe with the 22mm. bar.
some members on this board actually teared the subframe with the SS 19mm bar.
it is better to be safe than sorry. it'll save you money in the long run.
Ive seen several torn subframes from itr and larger bars, with the use of beaks and similar kits.
Of course Im overly cautious, but I recommend something a little better:
http://www.a-spec-racing.com/product1.php
You can also buy an itr bar + plate from them as a combo
http://www.a-spec-racing.com/product2.php
I dont see why it wouldnt work w/ the 5th gens as well
go with the beaks kit. beaksproducts.com i have it on my CX, you either need Integra rear LCA's or after markekt ones, i have megan racing lca's so i needed to get beaks 99SI kit for the endlinks, but if you get 92-95 si or integra lca's go with the EG/DC quickswap kit. its the best investment i have made on my car yet.
huh I thought they were the same length
ok oh well
ok oh well
