Stripped bolt question 5 hours down the drain
Old Sep 6, 2004 | 05:17 PM
illicon2003's Avatar
illicon2003
Default Stripped bolt question 5 hours down the drain
Ok I'm trying to remove the power steering hose from the valve body but the 14mm flare nut is stripped. My inspection has been up since the first and I need to get this power steering hose off so I can JB weld a new one on since mine is cut up above. 2 cut ones = 1 good one....
any reccomendations....it's a tough space to work in.. the 13mm won't hammer on and I don't have vice grips
Old Sep 6, 2004 | 05:19 PM
honura's Avatar
honura
Seni
try hammering it with a flat head.
Old Sep 6, 2004 | 07:17 PM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
Go to Autozone or any auto parts store and buy a kit that removes striped bolts.
Its around $5-10... you might not think its worth it just for a one time use, but beleive me, itll come in handy later on.
Old Sep 6, 2004 | 07:25 PM
illicon2003
it's the head of a nut...what you are referring to is a die/tap set...which is for threads on studs both male/female....I don't think that will work. thanks though
I'll try a flat head tommorow
Old Sep 6, 2004 | 10:16 PM
CivicRacr's Avatar
CivicRacr
craftsman has those stripped bolt head sockets...
Old Sep 7, 2004 | 08:24 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
go to your nearest sears and get the craftsman bolt-out set...
we used it the other day for a completely rounded off nut...
Old Sep 22, 2004 | 05:38 PM
apowe96's Avatar
apowe96
apowe96
haha you can always try the gator grip i have had luck once or twice with that beast
