ordered the b16a2
Old Sep 24, 2004 | 12:30 AM
  #41
EVO VIII's Avatar
EVO VIII
Imports over Domestic
I looked at the site and damn..the B16a motors are cheaper than the b18 series and h22. rated at 160hp that isnt bad. If I had a honda I would probably do a b16 swap too as is looks like a better deal. Is there a reason that the b18/h22 (except LS b18)are way more expensive?
Old Sep 24, 2004 | 05:05 AM
  #42
carlitosir's Avatar
carlitosir
Eventhough b16a's are in fact cheaper then b18c and h22 that $difference$ its not all that much, you might be looking at the (88-91) first generation of b16a (10 HP less than the rest of b16a's, and cable tranny). those you can get cheap.
Old Sep 24, 2004 | 10:53 AM
  #43
Nemesis4's Avatar
Nemesis4
NAB16A
I'm having a problem w/ my knock sensor. I ran the code and it gave me 23 so I looked and the knock sensor wasn't even wired up. So did some research and wired it up and the check engine comes on. Same code so i'm assuming that the knock sensor is bad. But, a buddy of mine said that I should have hooked it up to a computer and had the ecu reset? I'm not sure what to do...Go and buy a Knock sensor or take it to a dealer and have then reset the ecu. P30 by the way sorry to leave ya'll hangin.
