dealership says there is no knock sensor on b16a2
i spoke with the parts dept of a dealership today and they said there isn't a knock sensor for the b16a2 engine is that true??
B16A2 in EG Civic
There are 6 lines to check on.
Engine Side ECU Side
Desciption Wire Color Pin/Connection
VTEC Solenoid Yellow/Green A4
VTEC Oil Pressure Sensor Blue (passenger side harness) D6
VTEC Ground Black chassis ground
Knock Sensor Red/Blue D3
Evap Purge Power Yellow/Black 12V power (hot in ON or START)
Evap Purge Solenoid Red A20
IN BOOST WE TRUST.
The knock sensor is threaded directly into the back of the block,a
service manual would do you a lot of good in times like these or
else its back to the good old search engine.
Still here... sorta...
