Rear Crossmember..
Hey guys. My brother has a 95 Civic DX Coupe. He hit a median while driving tonight, and the rear crossmember is cracked towards the passenger side. Because of this, the rear passenger side tire is bent all out of proportion. I got under and looked at it tonight, and the crossmember is welded on. Is there any way to remove it and replace it with a donor crossmember? Can a crack on this be welded and corrected? Please help asap. Thanks alot, Michael
its possible to fix small tears and cracks by welding on steel plates, but if its bent out of shape (i.e., suspension pickup points are in the wrong place) you'll need to have a frame shop look at it (fix it or call it a total loss).
