Pros & Cons of High Final Drives?
Old Aug 12, 2004 | 10:49 PM
yblaster's Avatar
yblaster
Default Pros & Cons of High Final Drives?
What is the pros and cons of having a high final drive? For example, the 4.785 final drive of the JDM Integra.
Old Aug 13, 2004 | 12:20 AM
MPerson's Avatar
MPerson
Pro: Top speed
Con: Low Acceleration
:dunno:
Old Aug 13, 2004 | 05:13 AM
Spood's Avatar
Spood
Sucka
Originally Posted by MPerson
Pro: Top speed
:dunno:
Isn't it the other way around for that?
High numerically:
Better acceleration, lower top speed, worse gas mileage
Low numerically:
Worse acceleration, higher top speed, better gas mileage
Old Aug 13, 2004 | 06:36 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
High numerically:
Low numerically:
you sir, are correct :cheers:
Old Aug 13, 2004 | 08:38 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
my friend has the 4.78 final drive. it's a joy to drive. car loves to rev.
granted it revs high on high ways, the acceleration is worth it.
plus the lsd is an added benefit.
pros: better acceleration, faster into the power band, revs stay higher during shifts.
cons: worse gas mileage, more rpms
pros out weigh the cons in my book
Project EVA - The Track Package
Project EVA
Old Aug 13, 2004 | 12:15 PM
Kai's Avatar
Kai
Rotorphile.
My two main concerns are the higher gas usage (higher revs = more crusing horsepower = more gas expended) and the higher cruising revs (more revs = faster engine wear.)
Most cars with quick final drives usually have a deep 5th to counteract it on the highway. I'd love to drop an 88-89 GTUs 4.3 into my car, however I would ideally need the trans from that car for it's special 5th gear and speedo gear.
Don't forget, with a different final drive gear, your speedometer will be off. My friend's BMW 2002 has new numbers taped to his speedo for this reason. :chuckles:
Old Aug 13, 2004 | 12:33 PM
MPerson's Avatar
MPerson
:werd: my mistake.
Old Aug 13, 2004 | 06:51 PM
Civic2Scooby's Avatar
Civic2Scooby
so throw in the ITR final drive and an LS fifth gear....done.
Old Aug 13, 2004 | 09:57 PM
yblaster's Avatar
yblaster
Would it be better to install a SRR 4.929 final drive instead of a JDM-R 4.785? www.srr-racing.com
Old Aug 14, 2004 | 02:22 AM
Kai's Avatar
Kai
Rotorphile.
Final drive gears of ~5.0+ are a seriously bad idea for a street car, IMHO.
