Relocating Ignition
Old Aug 3, 2004 | 10:34 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Originally Posted by Outxider
put a different key ignition in the stock location and that one wasnt hooked up, and relocated his real workin one under the dash...
just make a copy of the key u have, and then break it off in the stock location one. then get a cover or somethin, and cover it up (to look clean). then re-rout the working ignition wherever u want it. is there somethin im missing, why this wouldnt work?
Old Aug 3, 2004 | 11:52 AM
honura's Avatar
honura
Seni
I fi where you the best way to do this is. get yourself a regular lock that are used in business gates. Relocate your ignition. and then when your gonna leave the car somewhere you can slap the lock under the dash by the pedals on the steering collom and that will lcok your steering wheel and you will not have any mod issues. Goodluck.
Old Aug 3, 2004 | 04:16 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
nvm. that would prolly defeat the purpose of having the steering wheel lock....oops
Old Aug 3, 2004 | 04:30 PM
honura's Avatar
honura
Seni
stupid questions get stupid answers I guess.
Old Aug 3, 2004 | 07:10 PM
relecom's Avatar
relecom
Nissan 240
it's mostly the security of having the wheel lock, but some of it is also 99% of the time I don't park on a hill, but if I had to park on a really steep hill I have seen the affects of the wheel working it's way to a more stright orientation, and even in gear with the e-brake on I have seen cars start to roll down the hill, or roll back into the car behind them.
but what I am going to do is get another ignition and key, and put that in the stock location, and relocate mine to the dash, as to the one in the stock location I will be putting a small cover connected to the key that can be kept unlocked, but if I need to turn that little cover to lock the wheel. It will be hardly identafiable, and thats the main issue. I snap off hub kit is on the list as well......thanks guys
Mark
