w00t for successful turbo install!!
Old Jul 18, 2004 | 11:50 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
Originally Posted by westcoaststyle
One thing that bothers me and I don't know why everyone does this is seen in this pic:
You really need to have the valve cover recirculating to the preTurbo intake pipe rather than just venting. Doing it with just a filter screws up the vacuum system... FYI.
it's debatable, but if u ever have oil passing your rings and going throgh the hose into your "intake" to the turbo... the oils could very well clog up the fins on the turbine.
its always best to run a catch can there also , in conjuncton with one for the pcv system
Old Jul 18, 2004 | 12:48 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Well, the tech at Total Seal said that it can cause blow-by. h:
Can you run multiple inputs and outputs on a catch can?
Old Jul 18, 2004 | 02:00 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
im pretty sure you can.
Old Jul 18, 2004 | 04:34 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by shifty35
I guess what I am saying is that the wastegate opens gradually even at low pressure, so it takes longer to spool. That's pretty much a known issue that a boost controller helps a lot with...
That's a boost leak, the exact opposite of creep. A boost controller can help, but your wastegate is sounding kinda weak to me. What brand/model are you using?
Old Jul 18, 2004 | 06:22 PM
westcoaststyle
ehhh... think about it though. If you have one line going from the PCV to the intake you're creating a vacuum from the intake. If you have another line from the valve cover to the intake pipe that's not creating the same vacuum (I don't think) so I don't think it would work correctly. Not sure though.... :happysad:
Old Jul 18, 2004 | 07:12 PM
honura's Avatar
honura
Seni
Nice setup man! Looks nice. Yeah I hate that little filter.
Old Jul 18, 2004 | 07:19 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
beat ya to it!
Old Jul 18, 2004 | 08:01 PM
shifty35's Avatar
shifty35
It's the stock Greddy 15g wastegate. I had to have it totally rebuilt (read: new center cartridge). Who knows what abuse the wastegate had to it...
Old Jul 18, 2004 | 08:03 PM
shifty35's Avatar
shifty35
BTW, I still read ~20 psi of vacuum at idle... even with that little filter. And I don't see how connecting the valve cover to a pipe under slight vacuum would help the vacuum system... then again, I'm a n00b to this...
Old Jul 19, 2004 | 01:49 AM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by s1ngle
beat ya to it!
x1000 less detail.
