So... hit the dyno yesterday :rick: - video added
Originally Posted by Kai
Pats, you don't know what a cutout is? Don't make me learn you :slap:
It's a remotely controlled part (manually or electrically) that dumps your exhaust where you want it (after the header on an N/A, as soon as possible on a turbo.) In other words, it's like cutting out your exhaust system whereever you want to to expidite the flow of exhaust. Ask me later if you have questions.
:rick: You are wise, grasshoppa.
Thanks for the props fellas. You all should take some pride in this as well considering a lot of you have had a huge hand in the development of the ride. :goodjob:
some pretty nice numbers. Ive finally had the chance to get my setup dyno tuned and to have my fuel tables corrected on my hondata. I was able to yeild 270hp and 201tq on 8psi on my b18c turbo. what are your af ratios looking like. I would think you could milk a little more hp out of your daily setting at 12psi. Im going to go check out your setup. either way congrats on the results.
The daily settings are very conservative so I'm sure I could gain more pulling some fuel out, but it's not necessary.
I have the fuel at home... will post if I remember to. Thanks.
:edit: And what CR were you at with those numbers?
Originally Posted by monicle
yeah im still at stock compression (10.6:1)
Come on Tony! Gimme more!!! :fawk:
You know when I get there I am going to find you and beg for a ride bro... not to thread jack but are you up for a motor build 1yr from March where I am getting stationed at Ft. Carson leaves for Iraq in March and I am trying to decide what I want to do for an engine since I am selling my turbo D setup this week.
Originally Posted by westcoaststyle
... I'm at 9.5:1 so over a full point of compression lower. Therefore, I will need to push more boost to create more power, but it will be a safer power (depending on the tune).
