REar discs from a 90-93 integra on eg??
Old Jul 10, 2004 | 03:01 PM
crxsiperf's Avatar
crxsiperf
Default REar discs from a 90-93 integra on eg??
I have a 94 civic hatch and i have aceess to a 90-93 integra rear disc break with sway bar , question is will it bolt up to my car or does it have to ceom from a 94-01 integra ? Also would the e brake cables work if the brakes are the right ones?
Thanks
Old Jul 10, 2004 | 03:40 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Different suspensions on that car man... it won't work. You need them from a '94-'01. You will also need E-brake cables for a 5th gen Si.
Old Jul 10, 2004 | 03:45 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Yes, they'll fit
(I know people that have da brakes on eg's)
The problem w/ them is that no one (including mugen) makes oem style TA bushings so when they die you will have a hard time finding good replacements. You could try to fix them w/ window weld in the future though...i guess that works.
edit***The bar...I dont know. Maybe not
