Idle...wierd
After driving in gear, when i coast, my civic sometimes idles at 1100 rpms, to make it idle normally (700 rpms), I have to step on the gas in neutral to make the needle bounce back to idling at 700 rpms. But it would idle around 1100 rpms again if i was to put it back into gear and gas it. Its like the rpm is stuck unless i gas it up and let it settle back to normal idle.
my idle is messed up it bounceds from 1000 to 1500 or 1500 to 2000 or 2000 to 2500, when i first start my car or after sum hard driving, (i was told it could be humidity), mybe my radiator is bad
auto or standard? My 5sp idles at 5-600 when warmed up, 1000-1100 on a cold cold start and in between depending on the temp. Keep in mind idle on an auto still has a load on the engine so the rpm should be a little higher i'd think.
