Rear Brakes Locking Up
Old Jul 6, 2004 | 06:10 PM
93civicsedan's Avatar
93civicsedan
Default Rear Brakes Locking Up
Like the title says my rear brakes keep getting locked up. I recently just upgraded them to disc brakes from a gsr. The car ran fine when I took it around the block a few times for a test. When I turned it on earlier today the rear wheels were wouldnt move. I then loosened the parking cable nut completely and it still was locked. Then I left the car alone for a few hrs and when I came back they were no longer locked. As I took it for a drive again they locked up again on me. Any ideas what could be wrong? What do you guys recommend I check? Thanks.
Old Jul 6, 2004 | 06:15 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I was thinking about the cable too. But this seems kind of odd. It's probably something simple that just doesn't happen all that much. Good luck
Old Jul 6, 2004 | 10:39 PM
Outxider's Avatar
Outxider
X-Motoring
could be a seized caliper. or something got caught in the ebrake cable mechanism. i had my right rear lock up one cuz a battery feel down my jdm arm rest and got stuck underneath the cable thus lookin my shiet.
Old Jul 7, 2004 | 03:30 AM
wilsel's Avatar
wilsel
It's a seized caliper. I had the same problem after doing a rear disc swap. Then I had to replace it, and I got to bleed the brakes all over again.
Old Jul 7, 2004 | 03:54 AM
bluetwo's Avatar
bluetwo
what would make the caliper sieze tho, and couldn't you just lube it or something......
Old Jul 7, 2004 | 10:15 AM
wilsel's Avatar
wilsel
I guess they build up moisture from sitting, and form rust on the caliper piston. Mine didn't seize until a couple hundred miles after the swap. You can buy a rebuild kit, and rebuilt it if you want to.
Old Jul 7, 2004 | 12:37 PM
93civicsedan
well i figured out that the rears only lock up after a few times of pulling on the emergency brake. after a few hours they become unlocked. could that be a seized caliper or something else?
Old Jul 7, 2004 | 12:51 PM
wilsel's Avatar
wilsel
Still sounds like a seized caliper to me. Unless your e-brake cable is too tight, which you've already checked.
Old Jul 8, 2004 | 05:53 PM
93civicsedan
how do I go about checking if the master cyclinder and booster are messed up? I noticed that when the rears lock up the brake pedal becomes hard.
Old Jul 8, 2004 | 08:49 PM
Nelson's Avatar
Nelson
Administrator
As everyone said, I bet its either seized or check your brake lines...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
