what works when engine swaping
leave the cams stock. Aftermarket 'Turbo' cams are a waste of money unless you you've done everything else possible to build up your motor. You'd be better off saving to build up the bottom end, or using the money to buy a good fuel management system like Hondata and getting it tuned.
Guest
Posts: n/a
thanks for the reply - I'm not swapping for power reasons, even though I know from dyno results that the AEM will prove a little stronger ....I plan on modifying it anyway, the AEM just has a better mounting system for what I want to do
- Nathan
.- Nathan
