Critique my custom LS turbo setup thus far!
SC34 powered LS-T
Ok first of all Ill start out by saying I have an integra, but Ive always posted in this forum before cus I used to have a civic, and to be honest I just dont think the guys in the teg forum are all that knowledgeable when it comes to FI h: Anyway, heres what Im planning on going with:
CRP Turbo Shorty Manifold (www.crpturbo.com, the company is local to me)
CRP Turbo Downpipe
CRP Turbo Chargepiping
Quicktime Exhaust Ecutout
Garrett T03/T04E Turbo...57 Trim with .63 AR Turbine, .60 Compressor
Tial 38mm Wastegate
OBD1 Conversion with Uberdata tuned by PhIZ
RC 550cc Injectors
Tial BOV
JohnnyRaceCar 6" Intercooler
Oil lines from www.fast-turbo.com
Undecided on what gauges I need at this point...(not sure If Ill even run any to begin with, seeing as how I wont be messing with the boost level)
The only thing Im unsure of is the turbine housing size on the turbo, cant decide if I should go with the .48 a/r or the .63. Any opinions welcome. I dont think Im missing anything, but tell me what you guys think of the plan so far.
CRP Turbo Downpipe
Tial 38mm Wastegate
RC 550cc Injectors
Tial BOV
it's my D in a B
I don't see a shorty manifold on that site... do you mean the log?
As for guages, I personally believe every honda should have an oil pressure guage and a water temp (because the stock one blows)... after that, boost and egt would be useful in the future.
clutch slipping boost
dont be stupid, get a boost and A/F gauge no matter how inaccurate. You never know if youre overboosting, and you definitely don't want to blow your engine.
CockBlockerator
:werd:
definately get a boost gauge (and get one that reads vacuum too)
that can tell you if you have any leaks
for example if you floor it and you reach full boost say like at 6krpm you have problems lol
also its always good to have it just in case there is ever a boost spike...
Still here... sorta...
Go with the MPP cutout. It's cheaper and it has a MUCH better warranty. I believe it has a 3 year warranty whereas the QT is only 90 days. :eek3:
The MPP will require you to buy the cutout pipe from Summit (or somewhere), but that's only ~$30 shipped. The MPP is $110 + shipping and they have AWESOME customer service. They will also do custom work for you if you want to use your own switch or whatnot. Very good guys.
Check them out: http://www.mccordcg.com/mpp/mpp.htm
I run a .60 A/R so you will be fine.
As for gauges, I run a Greddy EGT and Autometer Oil Pressure. My BC reads my boost level and keeps a peak boost level in memory so I can check it. It also holds my most recent boost level for like 2 sec. when I come out of boost so I can look down and see it. It's the Greddy ProfecB SpecII.
hih
hih
My teg runs that turbo. Spools nice and low, Pulls hard all the way to redline, good choice. Boost is good, then as money allows oil press, water temp. EGT is kinda, meh. A/F gauges are next to worthless. Unless you drop the change for a wideband gauge. Is a cutout absolutely neccesary? Cause unless you plan on running two chips, you're going to go lean when you change your exhaust dynamically...
-PHiZ
-PHiZ
CockBlockerator
I know that A/F guages arent the best, but they arent completely worthless are they? They give you some kind of rough idea, don't they?
i guess it can be slightly useful at WOT in which case if should show as rich,...
it's my D in a B
