Just did a Compression Test
Old Jul 1, 2004 | 10:47 AM
MPerson's Avatar
MPerson
Default Just did a Compression Test
Stock Internals on a D16Z6, I did every cylinder a few times to get out the odd readings.
Cylinder #1: 181psi.
Cylinder #2: 180psi.
Cylinder #3: 187psi.
Cylinder #4: 189psi.
Pretty good for an engine with 129,xxx miles.
Old Jul 1, 2004 | 11:01 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
very good numbers.
Question:
will my compression readings go down with altitude?
Old Jul 1, 2004 | 11:08 AM
MPerson's Avatar
MPerson
Originally Posted by s1ngle
very good numbers.
Question:
Yes, the higher you are, the lower the psi. If you were ever to get a turbo, you may have to run 8psi to be equal to 6psi, you know what I mean.
Old Jul 1, 2004 | 11:46 AM
Jafro's Avatar
Jafro
I'm made of meat!
Good numbers. Just keep the oil changed, and don't go over the timing belt maintenance schedule, then I'd say it would run forever.
Old Jul 1, 2004 | 12:06 PM
MPerson's Avatar
MPerson
The timing may be retarded by a tooth or two because I can hear some valvetrain noise that shouldn't be there. I'll take the cover off and look at it tommorow.
Old Jul 1, 2004 | 12:10 PM
s1ngle's Avatar
s1ngle
i wonder how much of a difference it makes.... too bad i dont have a compression tester here at 300 feet to compare to my 6500 foot reading.
Old Jul 1, 2004 | 12:27 PM
Jafro's Avatar
Jafro
I'm made of meat!
You probably have loose valves if you're hearing valve train noise. You probably just need a valve adjustment. A slipped timing belt is a pretty big deal, and it should either always run like shit or not run at all if that happened. You shouldn't drive it at all until it's fixed if you did jump time. It could jump again and hose your motor.
Check your timing marks, but I bet you find the problem under your valve cover. Loose valves will rattle, but they'll still stay tightly closed because of the valve springs. Comprendé?
Old Jul 1, 2004 | 12:34 PM
s1ngle's Avatar
s1ngle
jafro-- see my new thread about Timing... I'd like your help on understanding something.
Old Jul 2, 2004 | 07:54 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
it actually makes quite a big difference. My friend's car makes a good 20-25 butt-dyno hp in michigan as compared to boulder.
Old Jul 2, 2004 | 10:34 AM
s1ngle's Avatar
s1ngle
20-25 butt dyno? so what, 3 hp real dyno?
