Just did a Compression Test
Old Jul 2, 2004 | 10:36 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
yeah, at 6500 feet I got like 170s across the board.. and I was like damn, no good! but my car runs great, and the numbers are dead even across all cylinders, so i can't really complain.
Old Jul 2, 2004 | 11:21 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Originally Posted by s1ngle
20-25 butt dyno? so what, 3 hp real dyno?
his car makes upwards of 315wtq last time we dynoed it, so 20 butt-dyno hp might be pretty accurate.
Old Jul 2, 2004 | 11:35 AM
MPerson's Avatar
MPerson
Originally Posted by Jafro
You probably have loose valves if you're hearing valve train noise. You probably just need a valve adjustment. A slipped timing belt is a pretty big deal, and it should either always run like shit or not run at all if that happened. You shouldn't drive it at all until it's fixed if you did jump time. It could jump again and hose your motor.
Check your timing marks, but I bet you find the problem under your valve cover. Loose valves will rattle, but they'll still stay tightly closed because of the valve springs. Comprendé?
Yea that makes sense. Ok I need a new feelers guage, I'll get that and check real quick if I need a valve adjustment.
Old Jul 2, 2004 | 11:58 AM
s1ngle's Avatar
s1ngle
SpG p0wa y0!
