B-16b piston in a B-16a block??
Old Jun 29, 2004 | 06:06 AM
Spoon_monkey's Avatar
Spoon_monkey
Default B-16b piston in a B-16a block??
Is it ok to put b-16b pistons in a b-16a (EF) block? Ive heard stories that the block height of the b-16b is much higher than a b-16a (whats does deck height mean? Cuz the b-16b has a higher deck height compared to a b-16a block).. Will this upgrade blow my engine? ( i mean will the valve touch my pistons due to lower block height? - if the rumors are right)
I have b-16b cams in my head so i wanted to raise my compression ratio to match the cams i have.. But im thinkin twice in doing it cuz it might blow my engine off..
Need help guys.. Or is there a site or articles in how to do this upgrade.. Need technical help really bad..
More Hp to ya all!! Drive safe..
Old Jun 29, 2004 | 06:10 AM
cowanpp's Avatar
cowanpp
Card carrying badass
I don't think you can do it, because I believe your valves will touch the pistons. You should go to http://www.theoldone.com and search the forums, etc. I think I remember this being discussed over there.
Old Jun 29, 2004 | 06:23 AM
Spoon_monkey
Cant register there.. dunno why, all its says is an error has occured..
Old Jun 29, 2004 | 08:55 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
You can use ctr pistons in a b16. Only modification will be to your stock rods. They need about a mm taken off each side to fit, then press on new piston.
Old Jun 30, 2004 | 05:25 AM
Spoon_monkey
tnx...
Can you also tell what deck height means?.. Is this the same as block height?
cuz a b-16b block has a much higher deck height than the b-16a..
Also when using the b-16b pistons, will this mod affect my engine the same as the b-16b or will it give the same results to a stock b-16b (head specs excluded)?
Old Jun 30, 2004 | 12:36 PM
Snoopy's Avatar
Snoopy
been there done that
yes
Old Jul 2, 2004 | 07:18 AM
Spoon_monkey
Tnx! I'll get one ASAP.. hehehe..
