electrical problem.....
Old Jun 14, 2004 | 05:55 PM
slow-ek9's Avatar
slow-ek9
Default electrical problem.....
i have a 99 civic cx....what is the best way to find a short circuit? i have a short circuit in the alternator/sp sensor under da dash fuse box...everytime i put a new fuse in and turn the key to on postition...the fuse blows..ever since that started ..my speedometer doesnt work...in case it was the alternator ..i replaced it already...??
Old Jun 14, 2004 | 06:26 PM
MPerson's Avatar
MPerson
Well you'll need to follow the wire after the fuse, since the fuse is blowing, it means the short is after the fuse. You may need to take out the guage cluster and possibly need to drop the steering column to follow it.
Old Jun 14, 2004 | 06:43 PM
honura's Avatar
honura
Seni
Dahm your in for a fun job!
Old Jun 15, 2004 | 02:14 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
that fuse powers;
blk/wht wire to the ELD unit
blk/wht wire to gauge cluster (alt light)
blk/wht wire to EVAP bypass valve
blk/wht wire to EVAP canister vent shut
blk/yel wire to EVAP purge control solinoid
blk/yel wire to VSS - without power this will not tell the cluster how fast you are going, hence your speedo problem.
blk/yel wire to primary O2 heater
blk/yel wire to secondary O2 heater
blk/yel wire to alternator
I'd disconnect each and every one of the sensors, check for shorts in the sensors and harness, and go from there.
good luck man.
Stick
Oct 22, 2003 09:02 PM
jaxrunner
May 4, 2003 12:48 PM
teamlegacy
Accord
2
Mar 30, 2003 03:00 PM
AadosX
Accord
11
Mar 14, 2003 09:53 AM
The Dude
Aug 10, 2002 08:09 AM
