which boost kit?
Old May 27, 2004 | 09:16 AM
importkustoms00's Avatar
importkustoms00
Korean DOOD
Default which boost kit?
ok what turbo is better for my civic?
Apexi kit= P18 ball bearing turbocharger
Turbonetics kit= T3/T4 Hybrid Turbocharger
greddy kit= not sure what kind of turbo is in it
Old May 27, 2004 | 09:31 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
id go with the turbonetics, its got a higher chance of making more power in the long run.
Old May 27, 2004 | 11:25 AM
supermac88's Avatar
supermac88
not OG but Old School
the Greddy 15g kit uses a Td04h turbo based on the Mitsubish Td04
Old May 27, 2004 | 06:25 PM
importkustoms00
Korean DOOD
thats a small turbo aint it?
Old May 27, 2004 | 07:07 PM
Paul's Avatar
Paul
Eater of Rice
b-swap, then do the greddy kit, 18g
Old May 27, 2004 | 07:23 PM
importkustoms00
Korean DOOD
dude if i had that kinda flow i would but all i can afford is one or tha other.
Old May 27, 2004 | 09:23 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
IMO a t3/t4 is way to big for a d16z6.
Old May 27, 2004 | 09:49 PM
importkustoms00
Korean DOOD
it is? y is this?
Old May 27, 2004 | 09:56 PM
white_n_slow
it's my D in a B
its designed for bigger motors... It works on the B16 because the B16 has a high redline, so slow spool-up isn't as much of an issue, the B16 also moves a lot of air. It would work OK, but you wouldn't make a lot of power until just before redline. With a smaller turbo, you'd be making good power from say 2700-6500 (or whatever the d16z6 redline is :thinking: ), with a bigger turbo, you'd have lag from idle to ~4.5k, and then a bunch of power from 4.5k-6.5k... just not as usable/pleasant to drive.
Old May 27, 2004 | 10:24 PM
importkustoms00
Korean DOOD
yeah mine would be a daily driver so i see what ur talkin about...but is it worth it? bein a small turbo ur probibly not gonna get that much power from..............is it worth $1300?
