Beater Died :(
check the distributor.... Mine actually burned itself to death while I was delivering pizza once :eek3: But yeah, that would make the car not turn over.
:edit: its probably not the headgasket. If it were, you would have had overheating problems before the car finally died, and you would still be able to turn the motor over (or at least it would try).
ok here's the scoop
i got off work & went back to check out the car..
1. all fluids were fine
2. car was not over heating
3. it did have a leaky valve cover gasket
4.starter is working ( or trying to push at least )
5. motor is seized......
no idea how the motor got seized being that all the fluids were up to par, but it did so i'm tryin to figure out what i wanna do with this thing now...
Originally Posted by Running925
ok here's the scoop
