Guys with 96-2000 civics, with GSR front leathers check in here
Old Apr 30, 2004 | 06:07 PM
illicon2003's Avatar
illicon2003
Default Guys with 96-2000 civics, with GSR front leathers check in here
Hey well I've been researching this for a few nights now and can't seem to find a write up on how to put gsr leather seats into a 6th gen civic. I read some places that only 3 of the 4 bolts line up and the 4th can be secured with a washer....Other places said swap the sliders...Anyone have any pictures of their set ups?
Old Apr 30, 2004 | 06:15 PM
Grifter's Avatar
Grifter
no pic
i had gsr seats in my old ek and i dont think a washer will do the trick
have you tried swapping the rails
Old Apr 30, 2004 | 06:41 PM
honura's Avatar
honura
Seni
Just put the 3 bolts in. Even in the 92-95 the bolt lineup is the same. You will not feel a diffrence with the 3 bolts the 4th bolt will be in the rear inner side. And your seat will not be moving around so go ahead and put them in.
Old Apr 30, 2004 | 10:14 PM
illicon2003
I haven't started yet.....the 4th bolt is important though, I don't want to die because of something so stupid
Old May 1, 2004 | 03:36 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
don't know bout the 6th gens but I know the gsr leathers in front bolt right without any problems, that being all 4 bolts..:dunno: i just got some 95 gsr front leathers myself from Josh
Old May 1, 2004 | 05:12 AM
Outxider's Avatar
Outxider
X-Motoring
ok, to end all i guess, i think, and it should....
3g teg front seats bolt in 5g civics problem free.
3g teg front seats in 6g civic requires you to swap the ek rails over to the 3g teg seats, after that its an bolt on affair.
swappin the rails at most takes bout 15 min, its held down i believe by couple of 12mm bolts. i have help my friend put my old gsr leathers in his ek and we swap the rails and it bolted in like stock. have fun.
Old May 1, 2004 | 05:30 AM
illicon2003
I'm pretty sure I figured everything out. You have to swap the inner rail from the 6th gen seat onto the integra seat.. Anyways, you guys have any suggestions on what to lube the sliders with?
Old May 1, 2004 | 06:31 AM
oc_civic's Avatar
oc_civic
mcc racing
if anything.. a LITTLE white lythium grease...
i used gsr seats and civic rails... worked fine was pretty easy
Old May 1, 2004 | 08:58 AM
llxzxll's Avatar
llxzxll
wrong buddy. putting only 3 of the 4 bolts in is like signing a death wish. ESPECIALLY, if the 4th bolt that doesn't fit is the inner back right (driver) or inner back left (passenger). each and every one of these bolts are necessary to keep your seat firmly planted on the base of the car and if you happen to get into a seroius accident or a rollover, you will most likely die or get crushed after the seat decides to leave it's spot.
just do yourself a favor, take an extra 15-30 minutes to swap the rails and they should bolt up perfectly fine.
Old May 1, 2004 | 09:40 AM
ragerized's Avatar
ragerized
dc4 ownerages
yeah, i wouldnt want to take my chances with something like that. besides, i like to do things the right way, and use all the bolts. h:
Ramman949
49
Apr 27, 2004 07:51 PM
greengsr2k
Mar 25, 2004 01:11 PM
Sportmode
Aug 22, 2003 07:50 PM
nightshocker
May 19, 2003 12:07 PM
egjoe
May 16, 2003 01:01 PM
