oil filter
Old Apr 26, 2004 | 04:42 PM
agent87's Avatar
agent87
Need zzzzz's
Originally Posted by taz77
i think the old filters were made by allied signal...which is like a parent company of frams, autolite, and some others... it's just easier to say they're made by fram.
Weren't they made by Filtech? I could be trippin' though.
I usually use the Pepboys Purolator copies (Proline) or I'll use Walmart Supertech filters. I don't worry about it too much as long as it's not Fram...
Old Apr 26, 2004 | 05:35 PM
sol2nr's Avatar
sol2nr
i use HAMP synergy. a quality JDM part. not just paying for the JDM part.
Old Apr 26, 2004 | 05:39 PM
maskedSONY's Avatar
maskedSONY
sounds like you guys might like to read this:
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old Apr 26, 2004 | 06:41 PM
OldSchoolSI's Avatar
OldSchoolSI
Old schoolin' 87 CRX SI
I guess I will be returning my fram filter tomorrow, sucks thats the only filter I can find for my 1st gen SI crx. Maybe Autozone or somewhere carries something different
Old Apr 26, 2004 | 06:45 PM
maskedSONY's Avatar
maskedSONY
im sure wal mart has an AC-delco filter.
Old Apr 26, 2004 | 07:56 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
whats so wrong with fram?????????????????
Old Apr 26, 2004 | 09:49 PM
agent87's Avatar
agent87
Need zzzzz's
Fram
Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. These filters are manufactured by Allied Signal, Inc. Please do not buy these filters. By boycotting it, we may be able to cause some change. I have personally had one if these filters fail and actually cause engine damage due to bits of paper and glue floating around in the engine.
For some inside dirt on Fram filters, see this email from an Allied Signal production engineer.
Fram Extra Guard PH8A
This filter cartridge has a small outside diameter with a rather low filter element surface area (193 sqin), and features cardboard end caps that are glued in place. The rubber anti-drainback valve seals against the cardboard and easily leaks, causing dirty oil to drain back into the pan. If you have a noisy valve train at startup, this filter is likely the cause. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time, but they often leak anyway. The backplate has smaller and fewer oil inlet holes, which may restrict flow, and is made of thin material.
From maskedSONY's link...
Old Apr 26, 2004 | 10:00 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
fram filters are also known for having the Oring gasket come off the filter and stick to the block,..if you dont notice this before putting on a new filter,..then it can cause a bad oil leak
Old Apr 26, 2004 | 10:07 PM
Im@ge's Avatar
Im@ge
So ugly it hurts..See?
Originally Posted by CivicSiRacer
I use Bosch or Mobil 1 filters.
Yeah I use Bosch too
Old Apr 27, 2004 | 09:49 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
hmm i have FRAM..... after reading that, makes me want to quickly change it
