Turbo a d16y8 engine?
Old Apr 25, 2004 | 10:26 AM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
there have been a lot of stock y8's running 10psi daily. If you want to go more than that, I'd recommend doing at least rods and pistons. I would also recommend getting head studs. I built the hell out of my D, and I'll be running 15-20 lbs daily. I also spent about $1200 on engine management...
Believe me, you can't just throw a turbo on your car, make it fast, and not expect to blow it up. I have boosted 3 different motors in my daily drivers, and never blown one. But I've taken my time, researched a lot, and know what not to do. REsearch is your best friend.
www.turbod16.com and www.homemadeturbo.com are a big help. On HTM's forum, there is a long thread about engine managemnt, and what you CAN get, and what will help your engine last.
Old Apr 25, 2004 | 11:29 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
Do Just head studs make a difference? Theyre very easy to do, which is why i ask....
Old Apr 25, 2004 | 12:09 PM
98WhtCivicEx's Avatar
98WhtCivicEx
^^That's Me!^^
What kind of engine managment would you recommend and is it needed if I run a low amount of PSI?
Old Apr 25, 2004 | 05:54 PM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
if you run low psi then you might just need a fuel pump and an fmu. a step up from the fmu and fuel pump would be the fuel pump, injectors and an afc. on this setup you can run 10lbs fairly safely as long as you get it proffessionally tuned. a step further would be hondata s200b, fuel pump, injectors, and a good tuning. if you want to go all out then get an aem ems or another standalone system.
Old Apr 29, 2004 | 09:15 AM
s1ngle's Avatar
s1ngle
ehem.... home.... made....turbo......com
Old Apr 29, 2004 | 09:30 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
SleeperCivicEX: D16Y8, Greddy 15G kit, VAFC, RC 440s, O2 simulator
11 psi daily
dyno'd at 220 whp
13.98 @ 100 on 17" rims & Perelli P7000 (street tires)
No internal mods, home tuned, over 2 years of abusive driving.
There's a testiment for ya.
Old Apr 29, 2004 | 09:57 AM
yellow civic ex
11 psi daily
dyno'd at 220 whp
there are always exceptions to the rule.
Old Apr 29, 2004 | 11:22 AM
Junia's Avatar
Junia
I'm just throwing this out there but how about a B20 and then turbo charge in the future. I hear they have some nice lowend torque. Would that be a good way to go? Maybe a turbo in the future. 2.0 liter turbo in a car that originally came with a 1.5/1.6
Old Apr 29, 2004 | 11:52 AM
Running925's Avatar
Running925
Your Powder Coater
If you looking for cost effective & a "Quick" car to play with.. WSC has shown you the results.. & if your looking for a long term project including $5000+ & reaching the "Fast" car range.. then SWAP / BUILD / BOOST is the project for you. Money is a big factor in this as well as the final results that you are looking for in the time frame you wish to have.
Old Apr 30, 2004 | 08:01 AM
Knightmare69's Avatar
Knightmare69
Hater
Just spend the 3g's on the edlebrock kit to tide you over till you figure out what you really want.
