Del Sol won't rev past 2500? WTF?
Old Apr 27, 2004 | 06:17 AM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by imlachg1
would you recomend doing this? ? My tps sensor is going mad, and I am going to replace that with a new one, but people who have had the same symptoms as I have had said to replace the ecu. I figured I might do so, but i might just switch to obdI ecu. what do you think about his setup here http://cgi.ebay.com/ebaymotors/ws/eB...475267792&rd=1 he has great feedback, and he also sells the jumper for 85 bucks im not sure what I'm gonna do, I'm gonna replace my tps, and if that fixes it I'll just be good with that, but if it doesn't i'm gonna replace the ecu. I'm not sure if OBDI is worth it. I am throwing a code for missing a o2 sensor, so that would fix that. What does everyone think?
bah....waaaay overpriced for what it is....not to mention the fact that the redline is a hazard with stock cams and springs....I would stick to a stock p72 ecu and the jumper...and yes this will get rid of the o2 sensor.
edit: scoop something like this http://cgi.ebay.com/ebaymotors/ws/eB...475832593&rd=1
Old Apr 27, 2004 | 06:25 AM
imlachg1's Avatar
imlachg1
As far as swapping, I have a 96 del sol type s, I have a 99-00 gsr motor. The question is what jumper do I need to run an obdI ecu? I read this on another thread, what do i need to do, it confuses me a bit.
96+ won't plus right up...
96-98 will plug into a obd2a harness
99-00 will plug into a obd2b harness
(information found here https://www.honda-acura.net/forums/s...obd+conversion )
Old Apr 27, 2004 | 06:32 AM
Civic2Scooby
you will need the obd2a to obd1 harness.
do you have the obd2a or b ecu now?
Old Apr 27, 2004 | 06:35 AM
imlachg1's Avatar
imlachg1
thats a good question, how do I know, it came with my swap of a 2000 gsr, so prob a obdIIb, but how do I know? what difference do the plugs have?
Old Apr 27, 2004 | 06:36 AM
imlachg1's Avatar
imlachg1
as far as the difference of the plugs between obdIIa and obdIIb
Old Apr 27, 2004 | 06:38 AM
Civic2Scooby
this is where I am thinking the problem is...because your two peice engine harness is obd2a and you are running an obd2b ecu....are you using the stock del sol harness or the 99 GSR harness?
Old Apr 27, 2004 | 06:41 AM
imlachg1's Avatar
imlachg1
to be honest, i really don't know, i had someone else do the wireing, how can I tell what the difference is. I can go look at the plugs that go into my ecu.
Old Apr 27, 2004 | 06:46 AM
Civic2Scooby
hmmm...I dunno honestly...I have never had to figure out what the wiring was once it was done, cause I have always done it all myself.....
Old Apr 27, 2004 | 06:59 AM
imlachg1's Avatar
imlachg1
i guess i could just look at the ecu i have now and write the numbers down and look and see what it is, if the ecu i have now is obdIIb, then the plugs have to be able to fit into an obdIIb ecu, the all i need is a jumper that is obdIb->obd1 right, amd i right in thinking this?
imlachg1's Avatar
imlachg1
also thank you for you quick reply's and helpfull information
Civic Type Sev
Dec 30, 2003 12:46 PM
Y2A
Accord
3
Oct 30, 2003 11:46 PM
DelSolSIinMD
92+ Civic/EL & Del Sol
18
Aug 23, 2003 03:20 AM
Nvious_Creation
14
Nov 24, 2002 07:44 PM
