Del Sol won't rev past 2500? WTF?
Originally Posted by imlachg1
also is it true that the tps for a 94-00 b18c1 are different from all the rest, i was reading on ebay, that the gsr tps's read backards from other b seriers and d seriers tps's? Please help. Also I have no helms manual for a 00 gsr motor. But, can anyone run down the process for checking the tps sensor?
I also am thinking of putting a new edu in, should I switch to an obdI or keep the stock 2000 obdII ecu? Help me out.
as far as changing to an obd1, do i just have to get an obd1 ecu(such as what) and then buy a jumper? What are the advantages of this? (note: I don't have emisions tests in Indiana)
obd-1 has less sensors, one less 02 sensor...less emmissions stuff to throw a code and make stuff not work.
would you recomend doing this? ? My tps sensor is going mad, and I am going to replace that with a new one, but people who have had the same symptoms as I have had said to replace the ecu. I figured I might do so, but i might just switch to obdI ecu. what do you think about his setup here http://cgi.ebay.com/ebaymotors/ws/eB...475267792&rd=1 he has great feedback, and he also sells the jumper for 85 bucks im not sure what I'm gonna do, I'm gonna replace my tps, and if that fixes it I'll just be good with that, but if it doesn't i'm gonna replace the ecu. I'm not sure if OBDI is worth it. I am throwing a code for missing a o2 sensor, so that would fix that. What does everyone think?
