Bolt Mesurements
Black Pearl
Originally Posted by 92eg6
does the lower control arm bolt that the sway bar link goes into the same bolt.
i know its 2mm shorter but NOONE has a 18 bolt only 16
In long, you will have to drill two holes in your subframe if they are not already there.
I don't know much about this model, hopefully someone has some more knowledge on this. You may want to try a search. I recall this being discussed a while ago.
99 CG3 Owner
Originally Posted by Hondaman
In short, no.
Black Pearl
why do you have to drill a hole for stock
Push to shock!
it's my D in a B
yeah, some cars have the lower hole, some dont. If not, just drill a 3/8" or 5/16" hole... not a big deal.
Take a quick look under the car and see if its there. It should look like the pic of the subframe I posted in the other swaybar thread.
:edit:This site is a how-to on the ITR bar, but it should be helpful... the only step you don't need to worry about is #7 http://geocities.com/bretq/swaybar_install.html
inspyral
Engine Swaps, Tech & Tuning
7
02-04-2003 11:59 AM
dnt94civic
92+ Civic/EL & Del Sol
4
09-21-2002 08:36 PM
