son of a bich, hondata problem....
I've tried running it without the map pluged in, and it still gives a ****ed up signal. No offense, but that was the first thing I tried. It still ran like crap, showed the map all the way pegged...
I'm using it with the p28 that just came out of my hatch when I swapped in the b18b. Yes, you did sell me the 3 bar map too. Honestly, I didn't try the base map chip that came with it, since I didn't know which injectors it was setup for. I've worked with my buddy Adam's Hondata, and helped him get a pretty sweet tune going, so I'm not a retard with it. I just can't figure this out! Boost at idle? wtf!
I didn't think you were supposed to use the P28 with the B18B. Why aren't you using the P74/75? I suppose you could try disableing VTEC and knock sensor, I'm still not sure if that would work. What's your fuel pressure set at? That could play a factor. in the ON position ar you throwing a CEL? is the hondata led lighting up or blinking? It's so hard to say what could be wrong from here, without physically seeing it.
Solid red light on the hondata box. No code when the key is in the ON position. But once we start it up, it goes into limp mode. He is using the 3 bar map sensor, and we've checked the wiring 80 bajillion times!
