steering wheel removal
Old Apr 7, 2004 | 09:04 PM
bfunk's Avatar
bfunk
Default steering wheel removal
i have a 92 si and i want to remove the steering wheel and the air bag for the mugen steering wheel i just purchased but i don't know how remove the airbag and the steering wheel can anybody help
Old Apr 7, 2004 | 09:10 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
1.) take off negative cable at battery.
2.) look on the bottom part of steering wheel. should be an access panel plate. remove plate. you should see a yellow plug. remove yellow plug. on the back of the plate there should be a red plug. put red plug into yellow plug.
3.) access panels on the side. open 'em up. should be two torx t-40 bolts. One on each side. remove 'em.
4.) Air bag should come right out.
5.) should be a blach connect behind steering wheel running to the horn buttons on the side. disconnect.
6.) get 19mm socket breaker bar. lock steering wheel, so it won't move much. bust a nut :rick:
7.) steering wheel should come out.
I've got helms. I'll scan and host. Don't got time tonight.
Project EVA - The Track Package
Project EVA
Old Apr 8, 2004 | 09:29 AM
bfunk's Avatar
bfunk
thanks i'm going to try it tonight when i get off from work
Old Apr 8, 2004 | 02:24 PM
Kai's Avatar
Kai
Rotorphile.
Most of the time, if the wheel has never been removed before, you can pull it off once you take off the main nut. There is a slim chance you might need a steering wheel puller though.
Old Apr 8, 2004 | 02:44 PM
Nelson's Avatar
Nelson
Administrator
Bumnah covered it well.
Just make sure you don't bust the nut.
And some people said they needed the steering wheel puller to prevent from being punched...err, by themselves.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
jschmid
Do It Yourself
31
Sep 29, 2014 12:09 PM
Ochdx
92+ Civic/EL & Del Sol
13
Mar 8, 2004 06:44 PM
surferkai
6
Aug 21, 2003 07:28 PM
hybridhondahatch
CRX & Pre 92 Civic
4
Jan 3, 2003 08:26 PM
