Big break kits...
Old Apr 8, 2004 | 03:41 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Originally Posted by bambbrose
what do you mean by abs is driven off of the axle? I have never heard of this... I would like to know what that means. from what i knew abs was controled by vehicle speed sensors reading different readings, and then the abs unit lets the pressure off of one of the calipers to stop the wheel from locking up.. what does that have to do with the axle?
enlighten me
the speed sensor works by counting little bumps as the axle spins, sends the info to the abs computer, the abs computer delegates fluid control based on brake force and the speed info.
The brakes themselves (the rotors, calipers, lines) don't do anything... they're just plain old hardware. :edit: For instance, I have brakes from an ABS teg on my non-abs civic, and they work the same way the stock ones did.
Old Apr 9, 2004 | 04:59 AM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
Originally Posted by MaxBoosT
The benefit of a bigger brake setup isn't limited to just locking... almost any brake system can be locked. Real performance is how close you come to stop before you lock. Many factors including caliper design and rotor size effect this.
By the way, it's "Brakes".
Not Necissary.. sure there is a benfit with a larger rotor ,heat disapation, however if you can lock your brakes with any setup then you have reach the limit of adhesion for your tires, and probably have too much brake, or not enough tire. Remember what stops your car, there was test in a magazine I can't remeber, they put bigger brakes on a Stock RSX, the braking distance increased by 10 feet, the said it felt better and they had better modulation, but for an $1100 big brake kit the felt the should have shorter stopping distance.
Old Apr 9, 2004 | 07:34 AM
Nelson's Avatar
Nelson
Administrator
Which kit did they use.
A far as rotor size, caliper stability and leverage affect on the rotor, which means a larger rotor size, those factors increase. Having said that, the more stable a caliper and more evenly it can push the pads to the rotor surface, the faster your car will stop.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Apr 9, 2004 | 08:43 AM
Solracer's Avatar
Solracer
I agree with that, however I believe the problem with the RSX was they had to put bigger rims to go over the larger rotors and that increased the rotating mass significantly which led to longer brake distances over a stock RSX.
Most Honda's come with pretty decent brakes from the factory and IMHO before some spends a lot of money on a big brake kit, they should replace their fluid, rotors and get pads with a higher co-efficient of friction, and they would probably be surprised with the result.
Old Apr 9, 2004 | 08:48 AM
Outxider's Avatar
Outxider
X-Motoring
click on my thread and u will find all ur answers.
click here
Old Apr 9, 2004 | 11:58 AM
bambbrose's Avatar
bambbrose
alright that makes sense by saying abs brakes are larger, I really just meant abs equiped civics have to have 14" wheels while the non abs ones only have to have 13" wheels... so even though the brakes might not be affected by abs honda still put larger brakes on the abs equipped cars. that is what I was getting at.. I dont know if the sols are the same though
Old Apr 9, 2004 | 12:01 PM
white_n_slow
it's my D in a B
Right. All abs cars have the bigger brakes, but some non-abs cars do too (like non-abs Si's, teg RS's etc)
Old Apr 13, 2004 | 01:26 PM
Nelson's Avatar
Nelson
Administrator
Agree, but the added benefit of a bigger brake upgrade (calipers as well) is the ability to brake hard multiple times without having brake fade....
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Apr 13, 2004 | 07:26 PM
Gusto222's Avatar
Gusto222
Man WHORE
have u checked SSBC -- they make a kit for eVerything!! -- im sure u can put tha kit that g0es ona 96+ HB(non-abs) onto yoru sol.. they have prettty much tha same braking set-ups
http://www.stainlesssteelbrakes.com/
Old Apr 14, 2004 | 12:21 AM
Nelson's Avatar
Nelson
Administrator
No offense, but those calipers are one of the most ghetto designed I've seen...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
