aight. fixed the tps problem. now i just have a jumpy idle between 1100 and 1600 rpms. VTEC hit fine now. I think thats just because i don't have the secondary o2 sensor hooked up yet.
i dunno, i think once i get the O2 on, it should work itself out. the car idled good when i had it plugged in before so...i just need a bung and we should be good
Vac leak. The only way a car can idle higher then normal is if it is getting more air then it is supposed to, the O2 sensor should have nothing to do with that.
hey didnt i say vaccume leak? another thing that may be a suspect is that iavc/eavc bull crap vavle.. = idle air control valve allows your vehicle to idle properly when you are not giving it throttle... check it clean it swap it. either vac leak or that valve... ithink i posted a link to another thread that had similar probs...
