Help with 1995 Honda Del-Sol please!
Old Mar 31, 2004 | 07:01 AM
Darren25's Avatar
Darren25
Default Help with 1995 Honda Del-Sol please!
Hello all,
When I put my 1995 Honda Del-Sol in reverse, it makes a slight squealing noise. But it only happens when I put it in reverse. Can anyone tell me what is wrong and what I should do to fix it? It has never made this noise before and only does it in reverse.
Thank you!
Darren
Old Mar 31, 2004 | 07:04 AM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
Automatic or Stick?
Old Mar 31, 2004 | 07:13 AM
Darren25's Avatar
Darren25
Default Automatic, sorry
Originally Posted by Solracer
Automatic or Stick?
Automatic, sorry bout' that.
Old Mar 31, 2004 | 07:34 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It might be that your brake pads need to be replaced. I know it sounds crazy, but the same thing happened to my friend's '96 Coupe. It only did it in reverse to begin with and then started doing it all the time. There's a little metal piece on the inner brake pads (disc brakes) that squeels when your brakes wear down to that point.
You should check those and go from there. It's a simple fix if it's those, just replace the pads.
hih
Old Mar 31, 2004 | 07:37 AM
Darren25's Avatar
Darren25
hih
Sweet, thanks for the reply, I'll have them checked!
Old Mar 31, 2004 | 07:57 AM
westcoaststyle
You can check them just by looking at them. No need to take it to a shop for something this simple. :goodjob:
Old Mar 31, 2004 | 08:25 AM
Darren25's Avatar
Darren25
Ok, cool, I have the Chiltons book, but can you go ahead and tell me where to look and what exactly to look for. And lets say the pads look ok, is there anything else it could be?
Thanks again,
Darren
Old Mar 31, 2004 | 09:24 AM
Solracer's Avatar
Solracer
It could very well be your brake pads just getting to the wear indicators, when you back up the car the pads shift a bit and it may be shifting jsut enough for the wear indicators to squeal when backing up, pull the wheels off and see how closed the metal tabs on the brake pads are to the rotor.
Old Mar 31, 2004 | 10:26 AM
Darren25's Avatar
Darren25
Thanks my friend, I will take your advice and thanks again for answering
jdmkings
Vehicle Classifieds
14
Jun 11, 2004 03:59 PM
WHITEPEARL ACC
92+ Civic/EL & Del Sol
12
Oct 3, 2003 01:17 PM
sprayed16
Aug 12, 2003 09:46 PM
RaceACCORDingly
Jun 17, 2003 08:09 PM
mizturyous
Apr 25, 2003 04:23 AM
