Where is this ???
Old Mar 25, 2004 | 01:09 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default Where is this ???
my check engine light is on, i'm trying to find the plug so i can do the paper clip thing. but i cant find the plug, i looked on the passenger side and took out the cover of the ecu, i dont see any two pin connectors. is it connected to something?
Old Mar 25, 2004 | 01:10 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
bTW... I got a 96 civic
Old Mar 25, 2004 | 01:11 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
did you look in here at the DIY? https://www.honda-acura.net/forums/s...d.php?t=125370
Sometimes it's up by your glove box so you have to open your glove box and pull the hooks down so your glove box will open all the way, and it's sticking up on the very right.
There's a pic on the diy.
Old Mar 25, 2004 | 01:14 PM
Grifter's Avatar
Grifter
this might help
http://www.c-speedracing.com/faq/06.php
Old Mar 25, 2004 | 01:21 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
still cant find it...
Old Mar 25, 2004 | 01:37 PM
bambbrose's Avatar
bambbrose
dude your car is obd2 not obd1 so your plug is a 16 pin plug... not the same as the rest of these other plugs. yours is located near the center console on the passenger side if I remember correctly. and the paper clip trick wont work. you need to go get an obd2 diagnostic tester... most parts stores will let you borrow theirs
WCS, you should probably edit the DIY so that it says for obd1 vehicles only that way we dont have as much confusion
Old Mar 25, 2004 | 01:42 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
thanks.. my friend has one of them... borrowing it
Old Mar 25, 2004 | 01:43 PM
bambbrose's Avatar
bambbrose
did you find the plug alright then?
Old Mar 25, 2004 | 01:54 PM
Wharbone's Avatar
Wharbone
I didn't know they were different in the way you check codes.
Old Mar 25, 2004 | 02:21 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
friend said the plug is under the steering column
