Flywheel install!! HELP!
Monicle: That's not bad for a driveway method. I might use it someday. Maybe if I ever find one that I can't get to separate the way I usually do it.
But if you have both front wheels off the ground, room for a big ass prybar, and a room to swing a BFH, I think separating the lower ball joint is way faster and easier. Just 2 bolts, get someone to pry on the lower arm, and 1 good whack on the side usually sets it free.
Of course, if you don't own a decent pry bar, your method is about the only sure-fire way to avoid tearing the lower ball joint boots. Probably also a sure-fire way to avoid possibly needing an alignment, too. I've run into a few that were hard to separate and I had to beat on them for a while.
About the flywheels: If you reduce the flywheel's inertia, you will have to slip the clutch more, and you will wear the clutch out faster as a result, so the whole less-wear thing is out of the question.
Originally Posted by Snoopy
did you say lifters? :eh: :squint:
Whoops... hehe... I've been watching too much Sunday Spike TV (Power Block). :happysad:
I run a Clutchmasters 7.5lb Flywheel on my B18C1. There have been times that I'll be slowing down for a light, push in my clutch and the motor will die because the flywheel is so light.
h:
Originally Posted by jeterkm02
i changed my flywheel and clutch in about 4hrs
inspyral
Engine Swaps, Tech & Tuning
7
Feb 4, 2003 11:59 AM
AwwsChwA
8
Dec 18, 2002 10:07 AM
jdmcrx22
12
Oct 11, 2002 08:38 AM
AwwsChwA
24
Sep 29, 2002 10:40 PM
