Flywheel install!! HELP!
Old Mar 25, 2004 | 05:20 AM
1995 B16A's Avatar
1995 B16A
Originally Posted by b16aEGcivic
:lmfao: hey man some people are fortunate enough to have people do their swaps for them and not have anything personal invested....
No need to be like that...... I wish I had the time and resources to do my own work... Aside from 5 classes a day at school, work in the evenings and weekends, I don't have the time to do this... Besides the fact that during the fall I'm nearly living paycheck to paycheck... Y'all should consider yourselves lucky if you get a chance to do something you want on your own time...
Old Mar 25, 2004 | 05:24 AM
Jafro's Avatar
Jafro
I'm made of meat!
I've changed a D-series Honda clutch in less than 3 hours before because it pays 5.5 hours. It was like giving myself a raise by busting ass. It takes practice to do it that fast, but it's not so bad. Yes that was with air tools, lifts, and a climate controlled garage. Don't try to do this in your driveway. You just have to know how to quickly separate lower ball joints and axles without damaging them, and have the right spares around, too.
Pull teh axles, pull teh linkages, pull the mounts, unclip the hoses and cables, drop the tranny... Installation is the same as removal. Just have a new dowel pin for the shift linkage handy. New oil seals for the tranny and rear main seal on the engine are a good idea, too (since they're like $6-7 each, and possibly could make you have to do the job over if they start leaking). I don't do that for other people's cars, but I do for my own.
If you don't know how to change an oil seal, separate ball joints without a pickle fork, or what a dowel pin is, get someone else to install your flywheel and a new clutch. This is not the answer to making any more power and there are a thousand other things you can do with much less work to improve its performance. If you don't already need a clutch, or your engine and tranny most of your engine and tranny are still OEM, then I'd go as far as to say it's a worthless mod.
Old Mar 25, 2004 | 05:28 AM
1995 B16A's Avatar
1995 B16A
If you don't know how to change an oil seal or what a dowel pin is, get someone else to install your flywheel and a new clutch. This is not the answer to making any more power and there are a thousand other things you can do with much less work to improve its performance. If you don't already need a clutch, or your engine and tranny most of your engine and tranny are still OEM, then I'd go as far as to say it's a worthless mod.
Won't a lightweight flywheel help increase revs?? I mean, I would think a weight reduction of this magnitude would lessen wear and tear on a motor greatly, and should cause quicker revs...
What do you think is the best mod for the money, keeping Naturall Aspirated?? Would cams and titanium springs/retainers be a good way to go on a b16a?
Old Mar 25, 2004 | 05:30 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Good stuff. I've always done them in my driveway. :dunno:
Old Mar 25, 2004 | 05:32 AM
westcoaststyle
It won't increase revs. It will speed them up to a degree, but it's not an incredibly essential mod. There's a lot more out there that you could that are a much easier install and will benefit you more. A good set of cams/lifters/retainers/springs as you mentioned. Much easier install and you should see good advances. You should also consider an intake manifold upgrade.
hih
Old Mar 25, 2004 | 05:40 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
you can skip separating the ball joints of you just unhook the lower controll arm. that way you can just swing the spindle completely out of the way. Its much easier that way.
Old Mar 25, 2004 | 05:43 AM
westcoaststyle
hmm... not a bad idea. I just don't know though...
Old Mar 25, 2004 | 05:46 AM
1995 B16A's Avatar
1995 B16A
Will an intake manifold upgrade help much without any internals??
Old Mar 25, 2004 | 08:27 AM
westcoaststyle
It would help with the installation of cams.
Old Mar 25, 2004 | 02:29 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
I know on my d16z6, a 10lb flywheel made an amazing difference. On a bigger engine however, it may not be as dramatic.
All you really have to know going into it is how to disconnect the shift linkage, ball joints, and have a mechanical sense to you.... It's not hard, that's why I'm dumbfounded that someone with a b16 in their car has never done it. If you have the money to throw at parts, and pay for installation, more power to ya. I don't trust anyone to do work on my car, cause every time I have in the past, it got ****ed up. Do it right, do it yourself. I've done probably 15 swaps by myself, and have two to do this weekend. If I can't get a honda motor out of a car in under 2 hours now, there were major problems with things stripping or breaking.
