coasting in neutral... bad???????
Originally Posted by qtiger
Partially true. You should never tow a car with its drive wheels on the ground.
Which is why AWD cars must be flatbedded.
Originally Posted by mxl36o
you'r not in control...cause you're in neutral... so in order you get in control, you press clutch ..and shift into gear. i assume the logic is that you will be able to quickly accelerate and maneuver to avoid accidents easier.....
"13 AAC 02.515. Coasting Prohibited
The driver of a motor vehicle, when traveling upon a highway, may not drive the vehicle with its gears or transmission in neutral, with its clutch disengaged, or otherwise cause the vehicle to coast. "
thats a quote from a state law book...
Originally Posted by TeHJuSTiN
Well automatic's constantly coast. If you've ever let off the gas long enough you'll notice that the engine rpms will eventually drop to idle. So should they be pulled over too? Even thought they can press the gas and get it back in gear, it's still not instantaneous.
well... heh... lets hope they dont catch you then
i always wondered how they got the awd's into the flat beds in the first place, or how they tow fwd cars that pull into => a meter spot etc...
It is not smart to have your car in Neutral (that is what the law is about) when driving on a public rode because you never know what is going to happen, and in a panic moment of the car was in gear and you need to get on the gas would you remeber that it is out of gear and not just step on teh gas?
Originally Posted by Solracer
You really have no clue how an automatic transmission works do you? The revs may drop to idle but it is still in gear.
heh.. that actualy happened to me... i was taking a sharp turn with my buick, and my passenger freeked out and grabbed what ever he could (shifter) and threw it into neatral... without me knowing it, so to accelerate out of the turn, i just was revving it... good times
Originally Posted by Ferio Man
ive actually heard that its illegal in some places, not like u could get caught but, thats what ive heard...cause ur not in total control
If that is the case, then shifting gears should be illegal, because you are not in total control for a second or so, depending on how quick you are.
