coasting in neutral... bad???????
Originally Posted by aero3685
The one thing I heard from somewhere before is something about the water pump. When you are coasting, it slows down alot, and cant cool as much. Im not sure... something like that. I would like to know the answer though.
Originally Posted by JoePannone
coasting saves on te clutch too :chuckles:
Originally Posted by mxl36o
well he does say..."ANY MANUAL TRANSMISSION"
BTW... its against the law to coast on the highway
thats because you're not in control of your car when your coasting in neutral
you'r not in control...cause you're in neutral... so in order you get in control, you press clutch ..and shift into gear. i assume the logic is that you will be able to quickly accelerate and maneuver to avoid accidents easier.....
"13 AAC 02.515. Coasting Prohibited
The driver of a motor vehicle, when traveling upon a highway, may not drive the vehicle with its gears or transmission in neutral, with its clutch disengaged, or otherwise cause the vehicle to coast. "
thats a quote from a state law book...
