Questions about stuff
Old Mar 23, 2004 | 01:44 PM
theguy387's Avatar
theguy387
Default Questions about stuff
Ok I'm not sure what this is, but it's busted. Is it the rack and Pinion?? If so, how hard is it to replace it.
Oh and by the way is a 15-gal 150PSI air compressor good enough for working on teh car ($200 at Sears :naughty: )
File Type: jpg
File Type: jpg
Old Mar 23, 2004 | 03:18 PM
bambbrose's Avatar
bambbrose
ya looks like rack and pinion... do you have steering issues?
those are teh biggest bitch to change btw.. you could do it if you want to but it just takes a while. long process
Old Mar 23, 2004 | 03:20 PM
Sasebonian's Avatar
Sasebonian
'Till All R one!!
Axles
Old Mar 23, 2004 | 03:36 PM
theguy387's Avatar
theguy387
For someone who has done some minor fixes like, tune-ups, axle changes, and clutch change... will it be hard??
Old Mar 23, 2004 | 03:40 PM
bambbrose's Avatar
bambbrose
Originally Posted by Sasebonian
Axles
doesn't look like the cv shafts to me... maybe some better pics... from farther out...
reason why I say this is you can kinda see the adjustment part for the tierod ends in the first pic... I think
Old Mar 23, 2004 | 03:41 PM
bambbrose's Avatar
bambbrose
It's not too hard just time consuming,
Old Mar 23, 2004 | 03:46 PM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
does that shaft directly go through the center of your rotor and does it have a gear at the end? if so it is your axles thats a maybe 45-1hr fix and it is all not that hard.
Old Mar 23, 2004 | 04:27 PM
theguy387's Avatar
theguy387
I know its not the axles because I've actually messed with the axles before (changed the CV boot)
Old Mar 23, 2004 | 06:44 PM
bambbrose's Avatar
bambbrose
like I said it's your rack and pinion
I will get you instructions or something sometime tonight/tomorrow so you know what kinda job it is.
wait...shit, you have a mirage don't you? I don't know if i can get you instructions then. sorry mang
although i did check on labor times and you are looking at 4.1 hours to have someone do it... probably 7-10 if you do it yourself. that is for a 95 mirage with 1.8l sohc
Old Mar 23, 2004 | 08:34 PM
ragerized's Avatar
ragerized
dc4 ownerages
thats actually your inner tierod. go buy an oem one and take it somewhere to get it done and then have an alignment done immediately afterwards.
