pulled head from d16z6
Old Mar 8, 2004 | 11:16 AM
compfreak2002's Avatar
compfreak2002
Default pulled head from d16z6
i am pulling my d16z6 to swap into another honda, i pulled the head and inspected the cylinder walls, they still have the crosshatching from the factory after 207k miles!i want a new jdm piston and ring kit while i have it apart, if so do i have to buy a new gasket set for the oil pan, can i use gasket maker for the intake and oil pan gaskets??? do i have to re hone the cylinder walls if i get new rings and pistons?? i know i need a new head gasket, and i am just going to clean the head up, if i pull the valves out of the head do i have to get a valve job to re seat them??
Old Mar 8, 2004 | 11:20 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
well the rule of thumb is that if you taking something apart to the point that something else can be done, then you might as well do it. Kinda like replacing the timing belt+water pump. Sure you could just do one but why not do both since youvae already gone through all that trouble taking it apart.
Old Mar 8, 2004 | 12:31 PM
compfreak2002
i have the timing belt, i dont know if its even worth putting new parts in this motor can i just use gasket sealer for the intake, and oil pan gaskets
Old Mar 8, 2004 | 02:55 PM
Kai's Avatar
Kai
Rotorphile.
For the oil pan, you can probably get away with it. I would definately use a new intake manifold gasket though.
Old Mar 8, 2004 | 04:45 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I agree, in fact get a Hondata gasket. They're about $60 and well worth it.
You can reuse the oil pan gasket, but be sure not to overtighten it or it will leak. Also, DO NOT use RTV on the oil pan gasket. It will rip the gasket if put on incorrectly. It's not needed.
Where you are now, I'd replace the headgasket, intake gasket, exhaust gasket and possibly the timing belt & tensioner.
hih
Old Mar 8, 2004 | 04:56 PM
fook's Avatar
fook
Boosted D Series
Off topic, Kai are you in Oregon?
I ask because of the Corksport reference.
On topic, I would do new gaskets, don't half ass anything.
The hondata intake manifold gasket is a good idea too, though the d series gasket was hard to get hold of when I was trying to get one.
Old Mar 8, 2004 | 05:27 PM
Kai's Avatar
Kai
Rotorphile.
Nope, I had to wait about a week for shipping to VA. It would be nice if I was close though... but then I'd spend way too much money.
Old Mar 9, 2004 | 03:28 PM
drew935's Avatar
drew935
Laguna Seca circuit
So Kai what civic did you buy? EG6 or ?
Old Mar 9, 2004 | 03:35 PM
Kai's Avatar
Kai
Rotorphile.
I don't own any Hondas anymore. Used to own a '92 Integra GS, crashed it, had an '86 Accord LXi, sold, then an '87 Civic Si, sold about a month ago. Only have the RX-7 now, but I stick around because I still like Hondas.
Old Mar 9, 2004 | 04:09 PM
supermac88's Avatar
supermac88
not OG but Old School
And becuase without gusy like him we would be screwed on the really really technical issues.
92CivicDX
92+ Civic/EL & Del Sol
8
Oct 22, 2005 07:46 AM
agent87
Jul 20, 2003 07:18 PM
ZiviCase10287
Mar 14, 2003 05:22 PM
ZiviCase10287
Mar 13, 2003 08:37 PM
Kai
CRX & Pre 92 Civic
Sep 4, 2002 05:48 PM
