d16z6 turbo fuel set-up
Old Mar 6, 2004 | 07:52 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
Originally Posted by ZiviCase10287
um i thought stock d16z6 was 9.2 or 9.3:1 CR???? also with 5 psi a FMU can be used i believe with stock injectors, if you get anything more i'd do AFC hack with dsm 450cc injectors... or if you have a lot of money go with the e-mange
yea, what he said. for just 5psi don't even bother with bigger injectors and all. just get an fmu...that's all you need. maybe later on when you decide to run more boost get the 450's...or 440's like me. the throttle is a little choppy with the afc hack, but it's not too noticable once you get used to it.
if you have a fully built motor then why are you only planning to run 5psi?? also...when you do decide to run more boost, get 440's or 450's, an afc, fuel pump (i have the walbro 255lph) and get it tuned by a pro.
Old Mar 6, 2004 | 08:20 AM
Civic2Scooby's Avatar
Civic2Scooby
he is only running 5psi because his compression is 10.8:1.......high compression + lower boost = more power then low compression at higher boost...but it takes better and better tuning the higher the compression and boost go.
Old Mar 6, 2004 | 08:25 AM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
high compression + any boost = lots more problems..
Old Mar 6, 2004 | 08:26 AM
Civic2Scooby
not with proper tuning....the lower the boost you run the faster and easier you can spool up said boost...soooo if you have a really good tuner and has experience tuning high compression low boost motors...then it is a great advantage....cause you can spool up 5 psi all day.
96-Turbo-Civic
92+ Civic/EL & Del Sol
5
Feb 15, 2004 08:34 AM
HondaPreludeVT
Prelude
4
Feb 10, 2004 05:43 AM
1niceturbols
Engine Swaps, Tech & Tuning
6
May 31, 2003 11:17 PM
jaje
News & Rumors Archives
12
Dec 26, 2002 08:41 PM
sho akkord
Aug 8, 2002 03:51 PM
