TSI Turbo Kit
Old Mar 3, 2004 | 08:47 AM
cashizslick's Avatar
cashizslick
Originally Posted by fook
t25 wouldn't be bad for a stock 6psi d16 kit though would it?
ebay seller still has zero feedback, think they are just getting started or something?
www.landspeedracing.com sells that turbo kit.
as does www.wiredspeed.com
Old Mar 3, 2004 | 08:48 AM
cashizslick
I like the fact that it comes with injectors, but I still might piece my own together.
t25 would probably be more than id ever need, as I won't run very high boost.
also, the jdm d15b is a shorter stroke version of the d16z6, and ill probably be dropping one in my car. Anyone know what the compression on it is?
Also, you think the 6-8psi would still be safe on it if tuned right?
And, what would you pay for it?
well, 8 psi from THAT turbo will be fine cause its not very big, but if you wanted to run 8psi from a 50 trim T3/T4 then you might have problems . . .
Old Mar 3, 2004 | 09:30 AM
Paulll's Avatar
Paulll
Hail Bent
if the seller has 0 feedback, dont buy from him.
the apexi kit > all
Old Mar 3, 2004 | 10:17 AM
fook's Avatar
fook
Boosted D Series
the apexi kit > all
Isn't the Apex'i kit = discontinued?
Old Mar 3, 2004 | 10:18 AM
fook's Avatar
fook
Boosted D Series
Originally Posted by qtiger
I just re-read the post...
What's this injector box crap? Additional injectors in the intake? If so, I would find out if you can option out of their fuel system and just get piping, manifold, and turbo. It is really easy to properly fuel a turbo system with some DSM injectors and a VAFC, or a Hondata. Either one would probably cost as much as their ghetto fueling.
Not a bad idea, so their injectors are some sort of extra injector and not stock replacements?
I think I am better off piecing my own kit together. Alot of people will sell just manifold turbo downpipe and wastegate in a combo, I can get my own piping done.
Old Mar 3, 2004 | 10:19 AM
qtiger's Avatar
qtiger
I can't tell from the description.
Old Mar 3, 2004 | 04:21 PM
cashizslick
That method of fuel delivery sux - your still gonna feel the boost transition.
VAFC hack or hondata are the ONLY good ways to do a fuel system on a turbo honda.
Old Mar 3, 2004 | 05:10 PM
fook's Avatar
fook
Boosted D Series
VAFC hack eliminates the need for the Missing Link Map sensor right?
Also, what do I need for that other than the VAFC, DSM Injectors? There some sort of little black box for the DSM injectors correct? Also, will I need an FPR or fuel pump?
Old Mar 4, 2004 | 01:41 PM
EJcivic02's Avatar
EJcivic02
I talk Before I think
the ONLY?
id say AEM and MoTec are pretty damn good too.
with the VAFC hack, bigger injectors (RC or DSM), Resistor box for the DSM injectors, FMU (possibly, and an inline fuel pump.
check out www.homemadeturbo.com and www.turbod16.org for some more info too.
Old Mar 5, 2004 | 06:14 AM
cashizslick
Originally Posted by EJcivic02
the ONLY?
AEM costs 1500$. VAFC = 300$ and Hondata costs 400$ for the S200 with all the crap you'd need for boost. I think logic tells us whats best for out buck here.
